| Message |
Here is what I made.. Pressure Checked One Cylinder at a Time.. No leaks.. so I gooped the "Brown Gasket" a little with Non Hardning, and my problems went away ..
I'm also using Early Heads ported to Fit late Lower Intake.. I was worried I was leaking on that seal.. I was not.. So it had to be the Upper to Lower Seal.. I had used the "Rubberised" the first Time, then Changed to "The Brown".. then the Third time I did the "All Out War" to find it, and made the Pressure Plate.. The only place I could not check was the Upper to Lower Gasket.. So process of Elimination.. Cj
